Use this task to view IPv4 operational routes.
- Select Mgmt Instance.
- Select Mgmt.
- Select the IpRoute tab.
IpRoute Field Descriptions
Use the data in the following table to use the IpRoute tab.
Name |
Description |
DestAddr |
Shows the destination address of the route entry. |
DestMask |
Shows the destination mask of the route entry. |
Metric |
Shows the metric, or cost, assigned to the route entry. If multiple entries exist to the same destination, the metric determines which route is used. Routes with a type of LOCAL have a metric equal to 1. |
Instance |
Shows the Management Instance ID. |
NextHop |
Shows the next hop for the route entry. |
IntfName |
Shows the Management Instance interface name for the route entry. |
Type |
Shows the type of route entry. |
